Huntindog
Sep 30, 2016Explorer
mike-s wrote:It could be said that your argument makes sense... Doesn't make it true.darsben1 wrote:It could be said that the earth is flat. Doesn't make it true.
It could be said the additional moisture comes from the human body.
Bottom line. The human body DOES introduce moisture into the air.
This is one reason why we must drink water,,, to replace it.
This moisture can cause condensation when inside a small heated enclosed box like a TT, when the outside temps are cold.
This condensation can cause serious damage to the TT.
If you want to eliminate this source of moisture, you can simply take the humans out of the box.... Of course this isn't practical, so other methods SHOULD be used.
If you do not believe this, or want to employ any of these measures... It is your TT, and your money and your choice to do so.
Happy camping
44,071 PostsLatest Activity: Aug 30, 2026
