I would like to replace my current LRC tires with LRD. The inly thing I can find stamped on my current wheels is "1870 lbs". Can nayone tell me if these wheels can handle 65psi?
Max for that rim if stamped with 1870 lbs is 50psi. Good idea to upgrade to bigger, higher capacity ST tire, will improve durability and overall longevity while reducing occurrence of castrophic failure. Best to upgrade rim than to run ST tires at lower than max psi as stated on the sidewall. We've experienced reliable service from our Maxxis tires over the last 4 years.
