Lantley
Feb 07, 2018Nomad
The slide is not intended to be used when it is in. Yes there maybe times that force you to use slide while it is retracted. In those cases use slide gingerly as the floor is typically unsupported.
Pretending slide is fully functional whether it is in or out is foolish.
The manufacturer is not going to approve using the slide while it is retracted because it was not designed to be used that way.
44,071 PostsLatest Activity: Aug 30, 2026
