bid_time wrote:
I don't see TM as a step up except in money. If you think you're going to save time or effort during setup i think you're kidding yourself. Maybe a Shasta type rv will work for 2 of you but your real cure might involve a new vehicle. JMO.
Compared to our last pup, a Coleman Mesa the TM is a breeze to set up.
No more back breaking lift the bunk with your back while trying to get the support poles in place. No back breaking while cranking the thing open. Just a minor tug and the lift systems do the rest. Unlike the pup no sway problems if you didn't load exactly right. For a small hard sided camper that will get you into CG's you can't go with a big TT fiver you can't beat the TM.
