azdryheat
May 28, 2021Explorer
Tranny fluid change
Got 70,000 miles on the current ATF oil, so today it and the spin-on filter got changed. I also dropped the pan to see if there was any sludge and it was clean. Love this Duramax/Allison combo.
Grit dog wrote:Cummins12V98 wrote:
2015 user guide simply says "Change automatic transmission fluid" or "Change automatic transmission fluid and filter(s)" then goes on to give intervals.
I see nowhere partial fluid change. Common sense tells me it's better to change "ALL" fluid if possible.
People do what you want and I shall also. Funny how it rubs some the wrong way when I suggest changing all if possible.
Yes, you’re right, and yes you’re wrong…
I too prefer the fluid replacement method getting all or nearly all the fluid out and replaced at once. However that is not how the maint intervals are called for on the Aisin. It’s basically half the fluid each time.
Maybe no coincidence that the intervals seem about 2x as frequent as they would seem to be.
