azdryheat
May 28, 2021Explorer
Tranny fluid change
Got 70,000 miles on the current ATF oil, so today it and the spin-on filter got changed. I also dropped the pan to see if there was any sludge and it was clean. Love this Duramax/Allison combo.
Seon wrote:Cummins12V98 wrote:
What about all the "OLD" ATF left in the converter???
You'll never get all the oil out, even by a professional shop
Next time someone drops their oil pan, best to install an oil pan drain plug. Much easier for the next oil change.
Yes you can. Fill the transmission up, according to the dipstick, remove the return line from the oil cooler, install hose fitting, start truck, pump out a gallon, refill repeat until nice clean fluid appears.
Did this on both of my old Ford C6 transmissions. What I did was start and start adding as it drained the keep up as helper went through the gears slowly.
no real reason to drop the pan. Only time the pan needs to be dropped is if there is some reason to do internal transmission work. That's what's nice about the spin on filter.
I went to the deep pan on both my trucks, rather than the shallow pan the truck comes with. So the pan did come down for that. Being overly anal mostly.
BTW, on both my duramax trucks, I did a drain and fill with allison transynd rather than the GM fluid. Lasts longer, holds up better, and NAPA sells it at reasonable prices.
