azdryheat
May 28, 2021Explorer
Tranny fluid change
Got 70,000 miles on the current ATF oil, so today it and the spin-on filter got changed. I also dropped the pan to see if there was any sludge and it was clean. Love this Duramax/Allison combo.
4x4ord wrote:
Yup.... many magic trucks but only one woman:)
Grit dog wrote:
^Interesting.
I haven’t done it yet, but on the 68rfe I recall reading about disconnecting back by the trans to do a fluid replacement. Maybe to bypass a thermostat that recycles fluid until hot, like you experienced.
Huntindog wrote:rhagfo wrote:Cummins12V98 wrote:
"I also use used oil in the gasket, can always remove by hand and not a leak yet."
The "YET" part is what scares me. If the filter says tighten a certain amount after contact I do so. Honestly if a filter can be removed by hand after 5-15,000 miles that is loose IMHO.
Ron, tighten by hand the 3/4 turn past gasket contact, it is tight. I didn’t say it spun off easily at change. I wear a playtex rubber kitchen glove for heat resistance and better grip. I have been doing this way since an oil and filter change on Dad’s 59 Ford 352. Destroyed the spin on filter getting it off had gone on with clean oil on the gasket, and likely a full turn after gasket contact, that was about 1967,!
The 2001 ran 10k between changes.
Mechanics trick: use old oil on the gasket. Then it will always release for the next change out.... Do not worry about a couple of drops of old oil on the gasket.
4x4ord wrote:
^^^^Trucks don’t need maintenance. It costs virtually nothing to replace a truck. Women on the other hand, they need maintenance.
Cummins12V98 wrote:4x4ord wrote:Cummins12V98 wrote:
If anyone has figured out how to do a fluid exchange on an AISIN please post method. IMHO it's stupid to not remove all the fluid.
Doesn't Ram include fresh clean fluid when you order a new 2022. Just think it would come with fresh engine oil, tranny oil, new brakes, tires and antifreeze. New paint and chrome, new seats, updated nav system, 425 HP and 1075 lbft of torque plus bumper to bumper warranty and all for just three easy payments of $9,000 plus a 1/2 worn out, tired old sheep that is ready to be turned out to pasture. What are you waiting for ... or if you really want to have something to get cranked up about you could turn off one block sooner.
I have always liked how you can rationalize buying a new truck when the mood hits. :B
Grit dog wrote:
Man, some of you guys are just incessant!
That said, 12V, why couldn’t you do a trans fluid replacement like any other trans via the cooler line?
