boogie_4wheel
Jul 13, 2015Explorer
I'd personally shut down at 230* (stop at a pullout, idle truck to circulate fluid and help cool transmission).
I hit 223 the other weekend while pulling in 95-105 ambient. All was well climbing the grade until we caught a motorhome, then a dump truck with a pup, and I was screwed. I was in 1st gear fluid coupling only, not going fast enough to get a decent amount of air across the coolers. We got stopped at some construction for a few minutes so I kicked on the high idle at 1500rpm to spin the fan faster and draw more air across the cooler, helped it cool down about 10*. Once we topped out and got going fast enough to lock the torque convertor again (above 25mph) the trans cooled right off to just under 200.
I was pulling only ~6500lbs. I pretty much had worst case scenario.
44,068 PostsLatest Activity: Jun 10, 2026
