rockwind1's avatar
rockwind1
Explorer II
Nov 28, 2020
tranny temp got to 250!! yikes,, troubling questions
i have F350 (details below in signature) been towing with it for 10 years approx. must be my year for problems. was coming back home and going up a very light grade i have gone up many times and as i got over it and drove for a few miles i looked over at my edge tunes 8 guage digital thing and the tft said almost 250 degrees!!,,i don't have it alarmed or warning light or anything and just keep my eye on it,, so not sure how long it was at 250. i have never had it that hot ever, it was running 145 ish the whole trip in these colder winter temps. anyway, i immeadiately slowed down,, made sure it was in 4th gear with tran lock symbol appearing ( i have learned that this is the best way to get my tranny temp down) went about 50-55mph for maybe 15-20 minutes and got it back down to 145-150 degrees. the only thing i can think of is that i am running gopowerhungry tunes, the hydrachip,, i have 4 tunes programmed in ( i used the edge consol only for a multiple guage setup) i have a 65 hp tow and a daily driver. i have forgotten to put it in the usual 65hp tow mode,,, i can't believe that would do it but something certainly did. i have had past history of minor probs with tranny,, when shifting down into 3rd gear, even with converter locked (according to lock symbol on guagae cluster) the tranny will slowly heat up. will also do it in 2nd gear with converter locked. the only place the tranny always runs nice and cool is in 4th, locked. it has never been a problem really, until now.
recommendations or advice? just got home and will check tranny fluid tomorrow but suspect it will read at normal levels,, will inspect fluid and probly have it drained and replaced,, (good by 200 bucks)
could it have been just due to the tune selection?
engine temp was ok at 220 ish. my truck does have habit of getting engine temp up to 240 ish at end of longer grades.
i usually watch my egt's and keep them 1200-1300 max, they normally run 8-900 i think ( i think this is pre turbo)
truck description approximately: 2001 f350 7.3L 4 door LB SRW 4WD 6.0L tranny cool, 6.0L intercooler, ballbearing turbo, fancy turbo connections, banks brake (doesn't work) john woods tranny, 185K on engine. towing a 11k 33ft toyhauler
