theoldwizard1
Nov 29, 2020Explorer II
I worked in transmission engineering over 30 years ago. While 250F is pretty hot for non-synthetic oil, it is not "over the limit". IIRC, things got bad over 270F. The simple thing to do now is pull the dip stick. If the ATF is still bright cherry read and does not smell "burnt", ho harm !
If you are using synthetic or even blend you have a lot more room. I think all Motorcraft ATF is semi-synthetic now.
BTW, you did the right thing, backing off.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
