Turtle_n_Peeps
Jul 13, 2015Explorer
marcsbigfoot20b27 wrote:Turtle n Peeps wrote:marcsbigfoot20b27 wrote:
Yep, its not just about the fluid.......its also how much heat the seals can handle. One seal failure can mean totally disabled trans.
I worked at a transmission shop for 4 years (23 years ago) Seen lots of burned up units, some with wasted seals and clutch packs where the glue that holds the fiber to the steel was gone.
Anything over 225 for more than 5 minutes and I would pull over or add a bigger cooler. It doesn't matter if you have full synthetic that can handle 350 degrees if the seals melt.
My truck stock would get up to 210 going up the rim in AZ. Added a way bigger cooler and now it only gets to 160 max ever.
Do you think seal technology has stood still for 30 or 40 years? Just like fluid and everything else, the technology has increased immensely.
Mark; where are you at? Time to straighten some of these people out. :B Your phone is ringing!!
Well I am a sucker for information. Please do show some evidence of how hot is safe for regular and synthetic fluids and the seals in the transmissions. I would love to know the real answer.
Remember that not all of us tow with a 2015, some of us are still old school ~1995-2005
I'm not an expert on transmissions although I have built a few in my life. But I listen to them. If Mark shows up he can give you the facts you want.
The same goes for oil changes. Some still think 3K oil changes are necessary. This is just not the case. How do I know this? From lab reports that "prove" this is the case.
Some people go to the extreme and get their tranny too cold. This is as bad on things as too hot.
Like I said in my first post. If properly loaded, the OP will NEVER see anything close to 250F unless something is wrong so it's a mute point anyway.
44,068 PostsLatest Activity: Jun 09, 2026
