thebudman wrote:
eHoefler wrote:
On a trip up the Big Horn in 2009, they were in a massive reconstruction of the highway, it was in gravel and very rough. I had an 08 Ram 3500 DRW pulling or fully loaded 40' fifth wheel crawling along at 3-8 MPH. The transmission never had a chance to lock up the convertor for 20+ miles. The tranny temp went well over 285*, pegged my added gauge with the sensor on the cooler line to the cooler. Stayed there way too long in my mind, engine fan locked in, warning light on, system is dinging, and still had about 7 miles to go. When we finally got back on pavement and was able to get up to road speed, everything cooled down very quickly, and seemed OK. Checked the fluid at the very next place I could pull over, still bright pink, and no smell to it at all. Called my dealer back in Mo., he said he doubted I hurt anything and the fluid seemed fine, just run it and bring it in when I got home. I was still under warranty, had 9,000 on it at the time, so I did as he suggested. Returned home a week later, made an appointment, had them check it over, all was in great shape. Never had an issue with the transmission and traded at 82,000 miles for the 2010.
Or, you could have got a manual transmission and not had to deal with any of this.
While what you say is true, the end result was no trans damage so in a strange way, his case is a pretty good testimonial to the durability of modern automatics and fluids.
