tim1973's avatar
tim1973
Transmission cooler options
Hi all, this is a good forum been following it for years as anonymous. This is a lil long, but hopefully yall dont mind. Anyway, looking for some thoughts from other RV'ers. I have a 2011 Denali Yukon 6.2, recently purchased a TT with 6400 dry weight and about 7200 loaded(checked weight on a scale) with about 650 tongue weight. When i first bought it, we brought it home which was about a 90 mile ride, some small hills etc. Noticed the engine temp got up to about 230ish and the transmission also got up to 225-230. I decided to update the cooling system and add a larger transmission cooler. Put the 40K cooler in place of the factory one, and replaced the water pump(AC delco), aluminum aftermarket radiator(With internal transmission and oil cooler, as the OE one had), new ac delco radiator hoses and tsat.
Took TT on a 4 hr trip, pretty much flat ground, and ambient about 80F. This time, transmission got up to about 140F, engine though, still was getting up to about 230 at times..then going back down to 215ish. So, I didnt like the trans not getting up to proper operating temp(With no trailer, its barely getting over 110F), so I decided to install a transmission thermostat/bypass. Got the tru-cool one. Heres where i wasnt sure what to do. I decided on installing the tstat before both of the coolers, allowing bypass until up to proper temp. i decided to have the fluid go to the external cooler first, then on to the radiator internal cooler, then back to transmission. Vs going to the radiator first, as the OE had. Ideas? Thanks!
My thinking is, this allows full advantage of the 40K external cooler, and will reduce the amount of heat being given to the radiator coolant...hopefully allowing engine to run a little cooler? So far ive driven vehicle about 45 minutes, with no trailer on it. Tranny fluid gets to 185 and so far stays perfect.
  • Interesting...what were the other options for that radiator ?
    Mine is a 1996 7.4L and it has OEM 3 row aluminum radiator. With a 7 fin ATF in tank radiator (cold tank). Albeit plastic tanks, but they aren't much involved in cooling.
    Maybe 'thicker' meant it has more rows, but just a guess, but since you say 'should've opted for 2 row'...says that single row is lower in cooling capacity
    Didn't know electric fans and must say not kept up with the newer models. Last time checked electric fan kits all said not for big block nor diesel. Maybe they have come up in fan electric motor HP these days.
    Oh well, you seem to be happy with the results and enjoy your ride !
  • Thanks for the reply. The transmission thermostat is set for 180. The new radiator I bought from radiator express. It’s a single row, however thicker than stock. The sales rep explained these provide considerably more cooling surface/capacity than oe. Instead of plastic coolers, all aluminum. Looking back I wonder if I should’ve opted for two row? Anyway, it Only gets warm when on freeway at speed. Cools down to 190-200 when in traffic. No fan clutch, has giant variable speed electric fan OE. Which works. I am still using the dexcool…and it was flushed very well, guess new ac delco tstat could be hanging up, won’t rule it out of course…but doubtful. So, yeah, I was not sure whether or not to plausible.
  • If I read your setup & changes...that much bigger ATF cooler is keeping your automatic cooler **AND** if your plumbed it back to OEM...that new ATF cooler is sending *COLDER* ATF into the main radiator.
    Meaning it was adding cooling capacity to the main radiator and maybe no more with the bypass. Depends on what that bypass is set for
    Ask what the 'after market' radiator is, as the OEM radiator is aluminum
    How many row?
    Staggered?
    Flattened?
    How many pass or sections?
    How many fins on the internal ATF radiator ?
    Finally :
    Check if the thermostat in good order ? It might be sticking
    How many times has the OATs coolant been flushed ? and assume with OATs coolant, not the good old American Green, right?
    Check your fan clutch, they do wear out. Just changed mine and wanted severe duty, but NAPA didn't have one in stock. So it now has a HD duty fan clutch (they both couple at about the same percentage water pump shaft RPMs...diff is in the bearings keeping it from becoming airborne). NEVER install a 'standard' duty fan clutch on that engine
  • Interesting report. I believe you are on the right path.
