72cougarxr7
Jul 14, 2018Explorer
I understand your aprehension on a multi use fluid.
A couple I have had good luck with are Valvoline Maxlife atf, and Amsoil.
The Valvoline Maxlife is a newer formulation that is similar to the low viscosity formulas like Dex6 and Mercon LV. It still seems to work fine in the older Dex3 applications.
Amsoil handles it a bit different, they offer a low viscosity formula and a traditional viscosity formula. I do prefer this, since you csn more closely match the viscosity to what the transmission was originally designed to use.
