RWDIII
May 01, 2015Explorer
Desert Captain wrote:dodge guy wrote:
Not sure if the V-10 has an Oil Temp sensor. I know my 02 doesn`t, not sure on the newer ones.
I spoke with the folks at Scan Gauge and they said that oil temp was not an option on the V-10's, even as an "X" Gauge function. I assume that would only be due to the lack of an oil temp sensor but running with coolant temp (digitally), displayed gives a pretty good view of the overall engine temps.
:C
I installed the scan guage I had on my 06 F150 on to my 2015 F250
for some reason you cant get oil temp and I no longer can get the slip function for the auto trans.I was able to get the trans temp after reprograming
the four displays I run are water temp,trans temp,RPM and voltage
I have noticed the temps are about 5 degrees hotter than the F150
programing
