looper wrote:
This sounds exactly what's happening with mine. It's most obvious when backing into my driveway which is a slight uphill. It has only "blown" fluid once that I am aware of because there was fluid on the front of my TT. I use the recommended Mercon fluid and
Which Mercon are you using? Ford changed their recommendation to Mercon V a few years back.
When backing up a steep or hard push, many folks will put their transfer case into 4LO to give better control and not make the transmission complain. Downside is the steering limits in 4WD.
Some guys are working on an override switch to permit 2LO (4LO, but leave front hubs unlocked) for situations just like this.
Hope you found what you needed on the other forum. I tried to PM you, but you have it turned off.
