Travel_queen_M7
Oct 11, 2014Explorer
Dave Pete wrote:
Regarding the free space. I assume you mean the space of the current furnace. In mine I have a space for a catalytic heater and no furnace. In place of the furnace (where yours is located) I have three kitchen drawers. The catalytic heater mounts under the left side of the kitchen counter down low by the door and floor. With the proper heater (look at Wave 6), and the back door window cracked, a roof vent cracked, a functioning CO2 detector, and the oxygen deprivation shut off on the heater, you might find you don't need a wood stove. I've learned the catalytic heater just sips propane and a stove top doesn't take all that much. With an additional tank stowed somewhere you might get several weeks of boon docking. I am replacing my horizontal mount tank (where your is located under the fridge) to a vertical in the stool closet accessed from the back right wall of the camper. With one tank there is still room for a bathroom sink and drain, and without a bath sink you could likely get two 20lb tanks in that corner of the camper, freeing up storage under your fridge. Just need to build a tank cabinet.
I like that idea. I know what you mean about things taking longer then you think. I look at the camper and see just doing parts at a time is going to lead into rebuilding the camper by the time I'm done. I want to replace the floor and the supports in the floor and that's going to be a chore to get done before winter. I still have t decided weather or not to take everything out and start fresh with an open concept or just try and utilize the space that's already set. Have t had time to sit down and draw up plans.
44,071 PostsLatest Activity: Aug 30, 2026
