Camper1092
Jun 21, 2018Explorer
The design flaw I mentioned was that the hinge allows water to collect inside the unit. Mine does not drain from the hinge very well and water stays in the tray area since it is not sloped forward. When they replaced the seal around the bunk they did not extend it past the opening in the hinge. The original seal also didn't extend past the seal. The picture of the new hinge design looks better to me. I have recaulked that lower seal area before since I assumed the water was possibly getting in that way. I will add more and possibly look for a better way to seal it. Does anyone know what is used under the hinge where the door is screwed onto the front wall. I was thinking water might possibly be getting in under that as well if the tape wasn't well installed or has failed. I don't want to have to pull it off if that's not necessary. I also received an email from StarCraft years ago that showed a diagram of a double bulb seal with a flap at the bottom of the bunk door. When I questioned why mine was different I got no response. The recommended part the dealer advised is for the double bulb like is currently working on it. I appreciate everyone's input and help. I will say a 10 year old trailer isn't that old. I had a Coleman pop up that lasted over 20 years without any issues. I check and recaulk regularly.
