slavco
Nov 07, 2018Explorer
Camper1092 wrote:
Where did you get the bottom double bulb seal from and do you remember the model/product # for it?
Not sure if you still need this, but this is the seal - http://edmontonrv.wsiefusion.net/Catalogue-2014.pdf - FR99 0130. I have used it for my 2003 Travel Star and it was an exact fit. You should be able to get your local RV shop to order it for you. One word of caution, it's not cheap :) I think I paid somewhere around $80 CAD for it.
It also doesn't solve the leakage issue, as some people pointed out, the hinge designed is flawed. It's all good when the trailer is stationary, however towing it in the rain forces water into the camper under pressure. What I did was buy a garage door foam gasket from Homedepot and used it to close off the holes on the bottom corners. Although this doesn't fully address the issue, the amount of water getting in is significantly reduced. I just know to soak it up from the front storage compartment when we arrive at our destination.
Good luck!
Slav
