valhalla360
Dec 12, 2018Navigator
Firetraveler wrote:valhalla360 wrote:
So what's the payload of the truck?
As mentioned, hitch weight should be up around 800-900lbs, so if not a beefed up version, you will likely be over the payload limit.
Engine should have plenty of power to pull.
Payload says it’s 1700 lbs
Doeas a wd hitch help ?
WD Hitch helps with the hitch limit but not the payload limit. Without WD, it's probably limited to something like 500lb allowed on the hitch. With WD, it's probably around 1000lb. (check to be sure)
Should be fine as long as you aren't loading a lot in the truck.
