carringb
Dec 12, 2018Explorer
Firetraveler wrote:
After some good advice I went to the expy forums.
Seems there is issues with payload as some have mentioned here.
All great advice here
Looking at pickups I think will be a better option for what I’m doing.
It's not necessarily pickup vs SUV. It's more of a 1/2-ton platform problem. Most 150/1500s would be in the same boat.
Some lighter-trim versions of the Expy might be just fine for you. But Platinum model, probably not.
No matter the vehicle you are shopping, be sure to look at the payload sticker on the door jamb. That will be accurate for the exact vehicle you are looking at. Shopping off "available payload" specifications can be misleading, since there is so much variation in configurations and trim levels. An F150 can have as little as 1,200 pounds (Raptor Supercrew) to 3,200 pounds for a 2WD regular cab max payload.
