Mickeyfan0805
Dec 13, 2018Explorer
Terryallan wrote:
Even if you manage to load the Tt to 6500lb, and I seriously doubt you will. Your hitch weight will only be 780LB. Leaving 920lb of payload for you, and your stuff in the Expe.
You have to understand. there are many on this forum that think you need a F350 dually diesel to tow a 200lb lawnmower. You don't
I actually agree with you that, at least as usage is described, the Expedition is likely sufficient. There are always options that are more capable/powerful, but that does mean they are needed or even better.
That said, I would caution the confidence in using these numbers. My sense is that the 1,700 is an internet number, not a real one. The math has to be done on the ACTUAL payload of the particular vehicle in question - using a number off the internet is pointless, as payload rarely actually meets that number unless you have the stripped down basic version of the vehicle (and, sometimes, it can be quite a bit lower).
Similarly, 12% might be the tongue weight, but it might be higher (it all depends on trailer configuration and loading). If you have a loaded trailer and know it is 12%, then you can use that number. Going off spec, however, I would argue that using 14-15% gives one more confidence that they can stay within their projected ratings.
Again, I agree that the Exp is likely sufficient, but I also feel one is best to work with real numbers when available, and more conservative estimates when not. Using an internet published payload (which is likely high) and a 12% tounge weight (which might be low) is more aggressive than I would want to be when purchasing new equipment without actual numbers to work with.
