Huntindog
Dec 18, 2018Explorer
valhalla360 wrote:Ummm. Run your rig across the scales. Get axle by axle weights, with and without WD.rjstractor wrote:
Yet another important factor is that if the WD hitch is adjusted correctly, the entire hitch weight is not carried by the vehicle alone- a portion of that hitch weight is transferred back onto the trailer axles.
This is incorrect.
A WD hitch does not transfer weight to the trailer axles.
What it does do is shift some of the hitch weight from the rear axle to the front axle.
Then get back to us.
