zul's avatar
zul
Travel Trailer showing signs of potential problems ...
Or are these REAL problems??
We just bought our first trailer (23ft Trail Cruiser by R-Vision), finished 2 great trips and now we are trying to figure out if 'THE SKY IS FALLING' or if we just need to maintain this thing properly ... so here goes the delemas:
1. Tiny bubbles, front and rear panels ... delamination? You can only see the slight waves in certain light (thanks to my very good eyesight). For example, other people can't see the waves at all, but I can (sometimes). Just starting to delam?? Everything looks to be caulked up really well. No problem ... Start of problem or Panic time?
2. Roof material: Coming up on the side rails. Not cracking or peeling but it is separating up from the ply-wood roof on the edges/rails. Upon touch, it leaves a chalky substance on my fingers. Is this the roof material failing or left over gunk from prior sealent/care? Should the material coming up / chalky stuff cause panic and expensive rubber roof replacement? Or can someone suggest a product to coat / seal and UV protect?
3. Soft spot in the floor running from the sink to dinette seat (6 inches by 3 feet). Yes, I've seen the floor issues in forum searching ... Can this be a small problem that will stay put or will the soft spot grow into a monster?
Right now, there are no leaks or signs of leaks inside or underneath. However, I don't want to think everything is AOK if we can prevent future problems.
We've looked over the woes of R-Vision and still feel good about spending $6800 on a 2005 trailer where 'everything works' and looks really nice. Or maybe the sky IS falling ... hmmm.
Thx for helping!!
zul
2005 Trail Cruiser QB23
