ScottG wrote:
Bigbird65 wrote:
ScottG wrote:
I've not seen any "blown out" Maxxiss tires. I'm sure it has happened to someone but they are the best ST tire out there by a WIDE margin.
...and what makes you say that? Not doubting you, just wonder where the proof is or is this just an opinion?
Personal use and tons of anecdotal evidence on-line.
I did everything right (speed, PSI, weight) but still had many tire failures including one (Carlisle) that suffered a tread separation just laying in the back of my truck under the canopy - and it had never touched the road, saw daylight or rain.
After installing a set of Maxxiss 4 years ago I have not had a single issue.
But you could have had the same result or even better possibly with Michelin, Goodyear, etc. correct? But since you didnt try these you dont really know. Maxxis may be good tires but they are certainly not the only good tire out there.
