smkettner wrote:
LaunchnRetrieve wrote:
OK, three things. why should I be looking for 75R14 instead of 70R14? I couldn't find the 205/70R14 on Goodyear's website so I took the tire guy at face value when he said they weren't available. And how do I know what my wheel width is? Is it stamped on the wheel where I can see it or will it be under the tire?
I don't think any 70R14 is made. Any chance you misread the tire?
I think you will need to switch to 75s that should be a bit taller but check the weight rating is not lower.
No misread. st205/70R14 is what's on the sidewall. These are Goodyear Marathons, original tires, on a 2003 trailer.
The tires are in great condition, the only reason I'm replacing them is because they are 11 years old.
