Ruthless's avatar
Ruthless
Travel Trailer Tires
I'm going to replace my Goodyear Marathon tires. What travel trailer tires do you use, and how do you like them?
  • Keep them aired up properly and don't overload them. That is the cause of the vast majority of blowouts (road debris is up there also but not much you can do about that).
    Keep in min the supposed china bombs are mostly the result of 90% of trailers coming with them, so no surprise 90% of blowouts come from them but some people are still shocked. Then they buy the expensive brand, watch the weights and air pressure and convince themselves it was the brand.
    Always bought the cheapest brand that meets the weight specs as my dad did before me. 1 blowout between us in 60-70yrs of towing and that was a broken leaf spring that swung out and ate the inside of the tire...no brand was going to survive that.
  • All four of my rv trailers came with 15"/16" ST type tires. I've always sold them and went with 15" P tires on 3500 lbs axles and 16"LT E tires on 5.2/6k axles.
    This way I can run 45k/55k miles over 7-8 years with no issues at any speed.
    On my non rv trailers with 7k-8k axles I use commercial grade all steel ply carcass 16" ST S637 Sailun load G. Also trouble free and easily go 60k miles in 7-8 years.
    Good tire brands depends on my trailer OEM axle/tire size and load range capacities plus a good 10-15 percent reserve capacity.
  • Currently using Goodyear Endurance that are 4 yeas old. Goodyear warrants them for 6 - time will tell.
  • I went with good year endurance and bumped the load rating up to the 80 psi one. Knock on wood 4 years no issues.
