goducks10
Feb 07, 2014Explorer
myredracer wrote:goducks10 wrote:
I had to have it done on a Heartland TT with Lippert axles. A specialized shop did it. $190.00 total. They hook up chains and a hydraulic jack and bend the axles back to straight.
Here's how it's donehttp://www.youtube.com/watch?v=pRyTeqYuGBk
Interesting that the guy said that the axles will bend again over time. If they bent that much to start with (3/4" & 7/8" out) and are going to bend again, isn't that a symptom of under-rated axles? Why not just buy new axles in one or two sizes higher rating? I don't think axles are all that expensive and especially if you end up having premature tire wear again. Axles are often too close to the weight they are carrying and there's not much of a margin.
As a matter of fact the guy that did my alignment said my axle material was soft and he put extra camber in. So Depending on who makes the axles or whether they're spec right yes the could just bend again. I knew I wasn't going keep the TT forever so I went the cheaper easier route.
