From a practical standpoint, the force against the lugs shouldn't change much. You will still have the same loading forces, the offset will only change the distances involved. That will effect absorption of the wheel torques by the rubber tire and it's belts, somewhat, but not enough to make the proper lug fasteners fail/not fail.
If I had to guess the cause of your fastener fails it would be improper installation, material failure, or poorly aligned wheels (in relation to the hub). Could some part of the wheel be holding it from total contact with the hub/drum?
