LVJJJ
Jun 07, 2016Explorer
I'd much rather have an aluminum roof than the rubber stuff they use now, doesn't tear or get black or leak (as much), lighter weight too. I LIKE the sound of rain on the roof.
As most have said, every manufacturer (good or bad) produces good ones and lemons. Even if you inspect the TT carefully on the lot, it could fall apart on you after a couple of trips. For us, the most important aspect of a TT is the floor plan.
So go from there, find one u like, show up in the morning to give yourself time to go thru it carefully (ask the salesman to leave you alone), or take a good trailer mechanic with you to check everything. Have them plug it in and put propane in the tanks and turn on everything. If they will let you, hook it up and tow it on the nearest freeway. However, most dealers won't let you, but at least ask. I only had one dealer that let me, turned out it was too heavy for the TV. Good thing I got to try it.
(btw, if the spare has cover on it, take it off, we ended up with one that had had the sidewall half scraped off, but didn't find it out till after the purchase).
We used to buy new TT's all the time and were lucky to always get good ones. After going too deep in debt doing that, we worked hard to get out of debt and now won't finance anything, all cash now. So, we only buy used. Since I know what to look for (and am good at fixing things, even bad water damage), when we find a decent clean, straight TT we negotiate a price and pay cash. Our current TT is a 22' 2004 Tahoe Lite by Thor of California. We knew that these TT's had terrible problems right out of the factory and couldn't believe the horror stories that were told right here on RV.net.
By the time we bought it a couple of years ago, all those problems had been worked out, so now it's perfect and everything works good. Somebody had replaced the entire floor and fixed some front end leaks. There were and are no other leaks anywhere. All appliances work, we like the floor plan and it tows great and straight.
