- B_O__PlentyExplorer IINot much different than any other trailer of this design in the same price range. Not much of it is Heartland. Someone else builds the frame, suspension, appliances, furniture, furnace, water heater, A/C, tanks, propane system. What's left for Heartland to build? They assemble the roof and walls and install all the other parts, same as all the other companies that sell a similar unit..
B.O. - CalicajunExplorerI have a 2014 Heartland Wilderness model 2775RB. With all the choices out there on the market I would not recommend the Heartland Wilderness level of travel trailer to anyone.
No walk on roof, axles and tires are under sized for the TT, side panels (on my unit)are cut too short and don't go all the way under the corner molding in order to be held in place. I also don't care for the wide spacing between the wheels. If one tire goes flat it will go all the way down to the ground. Cost to me to replace the rim was $198.50 plus the cost of a new tire. Every and I mean every water fitting in the trailer was loose and leaked.
If your heart is set on a Heartland Wilderness. I can make you a good deal. :) - Cannondale61ExplorerI have been happy with my Wilderness. Fit and finish were acceptable, appliances are standard issue for most travel trailers. Plan on getting rid of the parents mattress, I replaced mine with one from Overstock.com. Hope this helps, the Heartland forum has a section just for Wilderness owners.
- RedRocket204Explorer
Dick_B wrote:
While you are waiting, for previous posts on this subject search this Forum for `Heartland Wilderness'.
And, since this forum's software search engine is not very good, use Google search with the following (I had to add a space between site: and rv.net so remove space):
site: rv.net STUFF YOU WANT TO SEARCH
or specifically for this thread:
site: rv.net Heartland Wilderness - APTExplorerHeartland started making the Wilderness line after I purchased my North Trail. No major issues with mine.
- Dick_BExplorerWhile you are waiting, for previous posts on this subject search this Forum for `Heartland Wilderness'.
