svjim's avatar
svjim
Trickle Charger for Ford Diesel
I have a 1999 Ford F250 diesel to carry my TC on. During the winter, I usually take the camper off the truck and store the truck in my garage. Works great, except for the battery. I am looking for some advise on trickle or battery maintenance chargers to keep my truck batteries charged during the winter. The camper is fine as it is maintained with solar.Since there are two batteries in the ford diesel I would like to know what others do to keep the batteries charged. I don't want to remove them from the truck, mainly because of my age.
Thanks,
Jim
  • Kayteg1 wrote:
    The "Turns on and off as needed"
    is a red flag, but you know that already?
    Not sure what you mean- it doesnt actualy turn on/off, not the best wording.
    But once maintainer has reached float, 12-24 hours, will stay there, holding volts @12.68.
    Unless I draw down battery, then it will go back to charge mode as high as 14.4 for a few minuets to few hours, depending how much have drawn battery down.
    Thats how most small maintainers function. Most are designed to use 24/7, I've never experienced one that boiled a battery. I have another Schumacher SEM1562A thats been in use for years 24/7 on our jeep.
    Except the HF you mentioned, it doesnt change what its trying to push into battery. I use one in the shop to periodically charge 7amp scooter battery, about 4 hours. Left unattended it will go as high as the 15+v its capabale of and would cook battery.
    I wasnt sure if the Schumacher would maintain 2 batteries but does it quite well- not a charger, thouhg will bring batteries up just not its purpose. I have parasitic drain of about 72 ma which after week of not driving batteries fall to 12.2v, 12.1v & below truck will not start.
  • Battery maintaining voltage on float circuit is set at about 13.3V , so charger fluctuating the voltage is not a maintainer.
