hey guys. I cracked a piece of trim, bottom edge of the front face. you can see the general area in the pic. its only a small section about an inch or so that's damaged. should I be looking for a piec...
The trim should be pliable, if it's not, it's old and dried out and needs to be replaced anyways. Just grab hold of it and pull it out of the track, take to your dealer and get a new piece. You don't need to try and slide it, just yank it out and put the new piece in by setting the bottom in the track, squeeze it down and put the top in; working from one end to the other inch by inch as you go.
