enblethen
Aug 09, 2021Nomad
Yes, disconnect the converter and try off batteries. If you have a battery charger put it onto the batteries. You may have bad battery or two. Separate the batteries and charge one at a time. Then test for voltage if you have a meter. Fully charged should be around 12.5 or greater.
More then one lighting circuit, would indicate 12 volt big issue.
Does the water pump work?
Make and model of your converter? Early converters had two outputs. One filtered and one dirty power.
