RVNoob123's avatar
RVNoob123
Truck and Trailer Towing Weight Question
Hello folks,
We were at an RV show and bought a travel trailer. After working with the rep we decided on the model listed below to haul with our truck. My question is:
With the specs listed below do you feel we are good with our choice? I just want to make sure the load is not too much for the truck.
Here we go:
2017 Silverado 1500,Z71 LTZ 5.3 Liter V8, 8 speed trans., 3.42 gear ratio with towing package (not max towing package) The specs say it can haul up to 9,300 LBS. We have heard not to be past 60% of the total the truck can haul. We are at 65%. We do not plan on hauling any cargo above 1,000 LBS and carry many items in the bed of the truck.
Max payload 1,710 LBS.
GVWR 7,200 LBS.
Trailer info:
2018 Keystone Cougar 24SABWE
Dry weight is 5,910 LBS, Loaded GVWR 7,800 LBS. tongue weight is 650 LBS. They say this is designed for 1;/2 ton trucks like mine (so the rep says)
I just want to be sure when we are traveling up inclines and down we would be fine. I figured this to be the best place since there is a lot of experienced travelers here that could probably help.
Thanks so much in advance!
