Camper_Jeff___K
Dec 03, 2017Navigator
SidecarFlip wrote:Camper_Jeff_&_Kelli wrote:SidecarFlip wrote:
Never seen a 'downspout' on an RV but there is a first time for everything I guess.
I had thought to install 1" PVC tubing at the drain ends of the two rear gutter ends and run the tubing down the back corners of the TC. The gutters now drain out directly onto the top of the rear jack motor housings causing lots of splatter. Not good placement but that's were the two items intersect in function.
With tubing downspouts you could use the water for your morning coffee...lol Rainwater makes good coffee water. I've used it more than once.
In fact I collect rainwater from the shop and garage roof in 350 gallon totes. Not because I'm 'green', because out well water is death on anything with a finish on it, loaded with calcium.
I collect the rainwater and use it in my pressure washer and suds bucket to wash the vehicles and farm equipment with.
Again, very nice camper. Always have liked S&S campers.
The S&S is a 2000 model year. Nine and a half foot. The bathroom is a little tight for a big guy but since I've lost 75 pounds, I fit in there a lot better. S&S did a pretty good job planning the storage space which for this size camper is really good. There is a +/- to every +/- in design and the balance is good. We'll keep this setup another 2 years before I start at working on a Transit or Sprinter conversion Class B.
44,056 PostsLatest Activity: Jan 12, 2020
