rockwind1
Nov 02, 2020Explorer II
JIMNLIN wrote:
Your older F350 SRW may have a 6830 rawr and is good for around 3300-3500 lbs in the bed.
Ne F350/F450 DRW pickups have the same 9900 rawr and good for a little over 6000 lbs in the bed. Maybe less with a crew cab long bed 4wd. Now add a trailers 800-1000 lb hitch weight.
A F450/4500 cab and chassis with 12k RAWR is good for over 8k+ rear axle payloads. All numbers depends on axle weights.
do airbags help at all?
