Supercharged111
Nov 03, 2020Explorer
mkirsch wrote:rockwind1 wrote:
thanks,,, my gvwr is 6300 lb my front axle is 3000lb, my rear axle is 3450lb with my stock tires 265/70 r17
Are you SURE about that?
Those sound like F150 numbers, and a pretty light duty F150 at that.
Usually a 2000's era SRW F350 has a GVWR of around 10000lbs, a front axle rating of 5000lbs+ and a rear axle rating of at least 7000lbs.
This. My 1500 has ratings right at the numbers the OP is spouting off. My 97 GMC dually has a RAWR of 7500, but the axle itself is rated to something like 8700# last I checked. 3500# axle ratings get you NOWHERE, as in 500# of tongue weight and no camper whatsoever.
