rockwind1
Nov 03, 2020Explorer II
mkirsch wrote:rockwind1 wrote:
thanks,,, my gvwr is 6300 lb my front axle is 3000lb, my rear axle is 3450lb with my stock tires 265/70 r17
Are you SURE about that?
Those sound like F150 numbers, and a pretty light duty F150 at that.
Usually a 2000's era SRW F350 has a GVWR of around 10000lbs, a front axle rating of 5000lbs+ and a rear axle rating of at least 7000lbs.
guys, my apologies,, that is actually my 4runner specs, i was going off a picture i took while ordering some stuff online for my 4runner, i thought it was the picture i took of my f350 tag. oops, i really thought those numbers were low as well. here is real info. honest mistake.
my gvwr is 9900 lb my front axle is 5200lb, my rear axle is 6830lb with my stock tires 265/70 r17
