Kayteg1
Nov 03, 2020Explorer II
So your truck can accept about 3800 lb on rear axle.
If you put 500 lb tongue on long stinger - you will put close to 1000 lb on rear axle from trailer alone. That will not give you much capacity for big camper.
If you put 1500lb tongue, you have no cargo capacity left (unless you can put it on front).
Other option is to tow 4-Runner on its wheels, if you have transfer case with neutral on it.
