DDavisIAMT's avatar
DDavisIAMT
Truck camper on a trailer
I came across a thread that had quite a bit of information regarding mounting a TC on a trailer to make a toy hauler. I have seen this done before by modifying a boat trailer, which worked smoothly.
I would like to do this, but I do not need the toy hauler part, I just need it mounted on a trailer so I can disconnect my truck.
What kind of weight can I expect from a 1970-1980's TC?
How large of a trailer will I need to mount this on?
My biggest concern is stability of the camper on a smaller trailer while turning, etc. I would like to use the smallest trailer possible and keep the costs down as much as possible.
My plan is to find a cheap old TC and gut it leaving only the bed and counters. I will be using my Coleman stove for cooking, I am not to concerned about water, toilet, etc. I have managed w/o those for years while camping out of my truck bed topper.
I am getting tired of the cramped quarters of my truck bed topper and would like something hard sided I can stand up in as well as camp year round in.
Thanks!
  • Is your intent to just have a gutted TC?
    The questions you ask require a little more info. The gutted TC would probably weigh anywhere from 1000 to 2000 pounds, depending on the TC. There are some that could weigh less. After gutting the TC, you then need to find its center of gravity, front to rear. This is the first step in determining the trailer length. In my opinion, you would best be served with a tandem axle trailer, due to stability.
    As cheap as possible, would be to simply buy a small travel trailer, as previously suggested.
    Wayne
  • I would, but the cost of even an old travel trailer is close to $1000 more than what it would cost me to do this. I could also remove the camper and use the trailer if needed.
  • Why reinvent the wheel? Just get a small travel trailer.
