donn0128
Aug 01, 2018Explorer II
Weights as listed using terms like "shipping" or "dry" are totally meaningless. This has been debated all over the forums for years. Most mgs now place a yellow tag somewhere inside usually in a cabinet that is suppose to list the weight as it left the factory. But even that is lacking basics like propane, and battery. None of us seasoned RVers look at the dry weights. As far as warranty return? GOOD LUCK! You have absolutely no basis to return it. If you have warranty issues that a dealer has attempted to repair several times and its still not right, then maybe you might have a legiminate reason to try and rerurn it. But even then, you are likely going to be offered a replacement. Its not what you thought you wanted? Your likely SOL. In that case sell it, take the financial hit and move on. Lesson learned.
44,067 PostsLatest Activity: Jun 05, 2026
