georgiekirschne
Aug 03, 2018Explorer
Travels with Yoly wrote:
I've told this story before and also posted a video documenting it. We bought a Travel Lite 770R based on it's advertised dry weight of 1,385 lbs and the dealer's word that consequently it would be safe to mount on our Ram 1500. On the way home from picking the rig up, I stopped at the Cat scale. The only addition to the camper was a house battery and the only optional equipment was an A/C unit. The 770R came in at 2,140 lbs. Subtracting a 165 lbs for the A/C unit (8,500 btu) and battery makes the true dry weight around 1,975 lbs or 590 lbs heavier than advertised. I called the dealer as soon as we got home and explained that this put out truck about 400 lbs above the GVWR and rear axle rating. The dealer, D&H RV refunded our money, no questions asked. They told me that they had always taken the manufacturers word on weights and never actually weighed on. My advice to every new TC owner is to immediately get a Cat scale weight just so you know what you've got to work with.
The Travel Lite 770R is the model I have and with which I have the weight concerns among other issues. Did Travel Lite as the manufacturer get involved at all or was it just between yourself and the dealer?
I raised concerns to the salesman about the weight before I purchased but he assured me that it would be fine. My 2015 F-150 is only rated 1639lbs and even with the advertised weight I would have been cutting it close, but with the actual scale weight I am definitely over my truck rating.
I probably should have talked to the dealer earlier along with the other workmanship issues which showed up early. I am still in the warranty period, so I'll take my chances.
44,067 PostsLatest Activity: Jun 05, 2026
