rooney77
Dec 04, 2013Explorer
Truck mods
Alright, this is more of a discussion thread than a true recommendation thread. Let's say you had 3k to spend. What mods would you do to improve your truck's on road ability and why?    I only ask bec...
msiminoff wrote:rooney77 wrote:
It's the stock axle. I assumed it was the 60 since that used to be the common axle.
Dodge stopped using Dana front axles in '02. The stock axle in your truck is an AAM 9.25 without a center axle disconnect… Unfortunately, in stock form it's undersized for our trucks, especially those tiny little ball joints and unserviceable unit bearings. The lousy factory steering linkage doesn't help either. However, if you throw a ton of money at the AAM (ball joints, u-joints, locking hubs, etc, etc) it can be made to do the job well.
A Dana 60 swap would be awesome, both on and off-road... though it'd be a lot of work and very expensive. Not worth the $$ IMO.
True, our Ram trucks are definitely not wheelers… but your rig looks awesome!
-Mark
