americanrascal wrote:
bobman wrote:
Start with the simple stuff verify you have a good connection on all wires and ground, that's the most likely problem.
Then if that checks out try tapping on the starter while your wife turns the key.
X2
While I always check all possibilites (batteries etc)-- every time I have had starter issues it has always been the ground for me- the connection from the strap to the block or frame. If the ground is red hot---well there's your sign.
X3 on the Ford ground strap. Took me forever to figure that one out.
