gregchambers wrote:
Have ordered a 2015 GMC one ton CC SRW SB 4x4 truck. It comes with Michelin LT265/70R18E tires that are rated at 3525 lbs for a rear axle of 7050 lbs. Although I should be OK with stock tires, I wouldn't mind a little extra capacity cushion. In checking other tire manufacturers the only other size that I have found without going to extreme size jumps (which my stock rims probably wouldn't support anyway)or 19.5" is the LT275/70R18E rated at 7640 lbs for an extra 230 lbs of capacity. Does anyone know of another 18" tire that jumps up significantly in capacity without radically changing size and diameter?
Thanks!
do yourself a favor before you spend any money on a guess. Weigh the truck and TC Then figure out if its just tires or if it is 19.5s and tires.
