billyray50 wrote:
billtex wrote:
As you are buying a new truck, it would be cool if the dealer would just swap out the tires for you...don't know if they will do that.
Another thing to consider; steel wheels are rated higher than aluminum. See if you can get steelies from a 1 ton SRW.
Let the dealer know what you are planning for your truck, maybe they will work with you.
Most dealers are clue-less about actually using trucks...you may have to educate them.
Good luck, B
Most steel wheels are not rated higher than true forged aluminum. At least that's what I was told by 3 wheel companies. Was told my 17"x 8 forged aluminum were stronger and rated higher than steel.
"True forged aluminum" is the key. Most of the aluminum wheels sold aren't.
