jonwegs wrote:
Lance's wiring harness has the positive and negative wires as 8 gauge, and Lance specifically said don't use charge cables smaller than 8 gauge.
You should read whole story.
Lance made #8 wires with special plug for refrigerator running of truck alternator.
You specifically said that you are not planning to do that ????
Mine Lance had the plug converted to standard 7-pins and I know the PO of my Lance wasn't the only one who did not like the hassle, when #8 wire is way more than necessary to recharge single battery Lance has. .
You are assuming a lot, while not checking much. So is your truck factory wire ignition-operated or not?
