mellow wrote:
Hemi Joel wrote:
I have never ran the batteries down enuff that the truck did not start, but I figure if I did, it should still start the generator to charge it back up.
I thought this myself, surprisingly the Onan generator takes a bit of juice to turn over. Ended up Having to get a jump start from a friend as I didn't feel like waiting for the solar to charge it.
After that I installed a Low voltage disconnect switch to my truck battery so it won't happen again.
I also carry one of those remote jumper packs that has a built in air compressor, 12v and 110 volt outlets as well. Just in case. I don't know how well it would do starting the cummins, but it should at least start the generator.
