jonwegs's avatar
jonwegs
Truck to camper wiring questions
I am new to the forum and owning a 2003 Lance 815. Vehicle is 1992 F-250 7.3 IDI. Also inexperienced with electrical systems.
My plan for the setup is almost always dry camping. So I am really wanting to get the battery charging system dialed in. I have already bought Lance's unique truck side male plug which I quickly learned I needed. My model does not have a built in battery isolator/separator.
I hoped I could wire the lance plug directly into my 7 pin in the bed of my truck, but the trailer wiring has smaller than 8 gauge wire for the power wire and ground wire. I tried this and the running lights work, but I now know the smaller gauge hot wire and ground won't charge the camper battery.
What do I need to do to successfully and safely wire my camper to the power generated when the engine is running?
Some say wire 8 gauge or bigger directly from the truck battery via an isolator, some say from the alternator via an isolator. While others say just wire it directly to the windshield wiper motor.
I will also have a solar panel (being shipped now), so ideally this will not be the only way my camper battery gets charged.
Any advice, links, or previous posts I didn't find would be greatly appreciated. And apologies for my ignorance on what seems like such common knowledge info for experienced folks.
  • Search constant duty solenoid will bring up a few old threads, also a couple in the TCU sticky. Simplest and effective is using constant duty solenoid-triggered by ign hot.
    also KKELLE14K post w/pic
    Ours
    I tied into battery, fused lead goes to solenoid, solenoids out goes thru thermal breaker then on to separate plug for camper. (ours will only accept 10ga)
  • “I will also have a solar panel (being shipped now), so ideally this will not be the only way my camper battery gets charged”
    An adequate solar system will be all you need to recharge your house battery on sunny/semi sunny days. What system did you buy? Will it fit on the roof?
